Converting azimuth from degrees to radians using Field Calculator; only zeros show up.
13129
16
10-02-2018 10:11 PM
RachelDiPietro
I am attempting to convert the azimuth field in a shapefile from degrees to radians using the Field Calculator, but after providing the equation, all the attributes in the new field show up as zero. Equation is [azimuth]*(pi/180). I also tried the calculation using the approximate decimal value of pi/180 and got the same result.
Attached are screenshots of the dialogue window and the problem with the zeros in the attribute table.
Is there a way to fix this without having to use Python or R, and if so how?
Any help would be greatly appreciated!
RachelDiPietro
It worked!
Thank you so much for all your help!
Best,
Rachel DiPietro
DanPatterson_Retired
Rachel... glad it worked out
RachelDiPietro
Whoops. Looks like I had forgotten the switch to Python parser. My apologies for the inconvenience!
Thank you again!
RachelDiPietro
Now there is a new error...
The syntax worked for the first two data sets out of seven after switching to 'Double' fields, but now I am getting this:
I have tried each of the syntax examples provided, exactly as they are with my field name. I changed none of the syntax from the first two datasets that did work vs the two I am working on now that don't work, and yet I received a general syntax error.
If the inputs aren't numeric (ie numbers) then Double won't work.  And the error is less important to me than showing the table and the inputs to the field calculator
RachelDiPietro
It was the parser. I had Python code on a VB Script. Working fine now.
Thank you again!
progress on multiple fronts... that is good
