Convert Coordinate Notation (Data Management)
2297
03-04-2011 05:43 AM
zhengniu1
Hi, All
My question is about the output by using Convert Coordinate Notation (Data Management) Tool in ArcGIS 10.
My input file is a shapefile format table has latitude, longitude, and other associated attributes. By using this tool, I can convert lat and long into UTM x and y where spatial reference is WGS84. But, the problem is that the outputs (UTM zone, x, and y) are placed in one column for all tuples. the default field property of that column is type of string.
If I want the outputs can be saved into three different fields with corresponding field names like UTM, x, and y, how can I do it? I check the help, it didnot say anything about.
Thanks for your help.
Niu
