Concatenate fields based on If/then statements
1355
08-26-2022 03:46 PM
Labels (2)
ChadTheismann
Hello, I'm looking for some assistance writing a formula that concatenates addressing fields if they are not null.  I have addresses broken out in individual text fields such as owner, address number1, address number 2, street direction, street name, street type, unit, city, and zip. All fields are text fields.   In the address fields, not all values are populated.  I only want values from fields that are populated.  If you couldn't tell, I am not experienced with VB or python. My database has ~50000 records.   I am using ArcMap 10.8.   Is there any way populate a concatenated site address field from populated address fields?
Example:
OWNER
SITUS_ADR1
SITUS_ST
SITUS_ST1
SITUS_TYPE
SITUS_CITY
SITUS_ST
SITUS_ZIP
J AND J DOE
1234
S
FIRST
AVE
PORT
AB
99999
CONCATENATED SITUS= J AND J DOE, 1234 S FIRST AVE, PORT, AB, 99999
MR. ABC
1111
<no value>
SEA
DR
PORT
AB
99999
CONCATENATED SITUS= MR. ABC, 1111 FIRST AVE, PORT, AB, 99999
XYZ
2222
<no value>
HWY Z
<no value>
PORT
AB
99999
CONCATENATED SITUS= XYZ, HWY Z, PORT, AB, 99999
VinceAngelo
Esri Esteemed Contributor
Yes, it's certainly possible, though I suggest you make the effort to learn Python (which is the easiest computer language to learn, ever).
Calculate Field field reference syntax is a bit more obtuse, so you want to follow the documentation carefully. That will result in a code block that looks like this:
def concatenateFields(f1,f2,f3,f4,f5,f6,f7):
    l = []
    if f1: l.append(f1)
    if f2: l.append(f2)
    if f3: l.append(f3)
    if f4: l.append(f4)
    if f5: l.append(f5)
    if f6: l.append(f6)
    if f7: l.append(f7)
    return ', '.join(l)
and an expression of:
concatenateFields(!SITUS_ADR1!,!SITUS_ST!,!SITUS_ST1!,!SITUS_TYPE!,!SITUS_CITY!,!SITUS_ST!,!SITUS_ZIP!)
- V
