Standard Distance Errors
1910
5
08-26-2022 04:34 PM
WaleedAbbas
I try to execute the spatial statistics "standard distance"analysis on a point feature class.
while the tool is running, an error appears as follows:
RuntimeError: The coordinates or measures are out of bounds.
Failed to execute (StandardDistance).
Thanks in advance
DanPatterson
MVP Esteemed Contributor
Standard Distance (Spatial Statistics)—ArcGIS Pro | Documentation
feature class in a file geodatabase?
Did you check the spatial index?
Are the data in a projected coordinate system.
... sort of retired...
WaleedAbbas
Deep thanks
the error was resolved when the feature class exported into a file GeoDB
Can I get an explanation for how this work
DanPatterson
Most tools work best when they are contained in a file geodatabase.  You didn't indicate where your input was housed or what it was.
WaleedAbbas
It was created in a personal GeoDB
DanPatterson
Pro doesn't support personal GeoDB's anymore
