Concatenate a URL followed by a Field Name Using Calculate Field
3471
08-21-2017 08:49 AM
SarojThapa1
I am trying to concatenate a domain URL followed by a field name using Calculate Field tool. In the Expression field in the Calculate Field window, the sql expression looks like:
PHOTO_URL =
<a href=DomainURL/FolderName/&" "&!PHOTO!>Photo</a>
However, in the attribute table, the PHOTO_URL's values are populated as
<a href=''DomainURL/FolderName/PhotoName.jpg''''>Photo</a>
I get an extra " at the end of the href. When opening the map service using the arcgis online, when the PHOTO_URL atttribute is clicked, it reloads the current web URL instead of redirecting to the photo url.
Any help or suggestions are greatly appreciated.
DanPatterson_Retired
python syntax
PHOTO = 'somephoto.jpg'
'DomainURL/FolderName/{}'.format(PHOTO)  # syntax line‍‍‍‍
yields
'DomainURL/FolderName/somephoto.jpg'
Field calculator syntax
'DomainURL/FolderName/{}'.format(!PHOTO!)  # syntax line‍‍‍‍
just put exclamation marks around PHOTO in the syntax line above so that it reads ... !PHOTO!
shan_sarkar
Saroj,
Can you share one record from your data so that I can test the issue?
~Shan
~Shan
SarojThapa1
Thanks for your response, Shantonu. The issue is resolved now.
python syntax
yields
