Clipping properties to Coastline... And the opposite
7215
11
08-19-2014 06:21 AM
EvanMacDonald1
Hi there,
I had great luck with my last inquiry using these forums so I figured I'd give it a shot again. I'm working with two layers, a coastline layer (polygon), and a property layer with many parcels which is also a polygon.
The coastline layer has a fairly accurate representation of the coast as it is now, but the property layer was drawn years ago and does not accurately reflect where the coastline is now. I want to use the coastline layer as the new coastline for the property. For 90% of the properties this is easy, as I can perform a simple clip and achieve my goal (As seen in the first attached image). But for the other 10% of properties which do not extend out past the coastline (as seen in the other attached image), this is not possible.
How can I get these properties to extend out to the accurate coastline, if this is possible at all?
Thank you
Tags (3)
EvanMacDonald1
Hi Joe, that's definitely a possibility. There may only be 1500 edits or so... It's not that outrageous. Just trying to take a day or so and find out an alternate solution.
Thanks
ChloeAsmar
Ok, check this out, 3.10 Adjust polygon to line
Might help
