Clip map
799
11-14-2012 06:44 AM
StratosVasilakos
I've imported as a basemap an aerial photograph from Bing Maps Aerial and I've located my area of interest. How can I clip a part of the map and keep only the area I want? I have a series of coordinates that I want to use but I want only to keep an area of the map. Also, in the part I want to keep will I still be able to zoom in and out without a problem to see my points?
Regards,
Stratos
AlexeyTereshenkov
The easiest way to make the basemap limited to an area of interest is to use the Data Frame Properties > Data Frame tab > Clipping Options.
