Check if points are snapped to lines
12043
9
04-06-2016 03:26 PM
ReneeGerasimtchouk
Is there a way to check if points are snapped to lines without having to export to geodatabase then creating a topology? Also, bulk snap these points?
RobertScheitlin__GISP
Renee,
  You should look at ArcToolBox >System Toolboxes > Editing Tools > Conflation > Snap
Snap—Help | ArcGIS for Desktop
DanPatterson_Retired
there is Finding dangles on line features—Help | ArcGIS for Desktop but I doubt you have that
you could use Feature Vertices To Points—Help | ArcGIS for Desktop  and just get the dangle points
or Extending multiple lines—Help | ArcGIS for Desktop but there are limitations again
so that probably leaves you with what you don't want to do, unless there are some free tools at www.ian-ko.com
ReneeGerasimtchouk
I'll read up on these for future use, thanks !
ReneeGerasimtchouk
I would like to check if my valves are snapped to pipes in my SQL Server database w/o having to export to geodatabase, create topology and check that way and also move any valves within a certain tolerance to snap to the pipe without having to do them individually.
oh grief... now server is thrown in.. perhaps someone else in your similar situation migh have a workaround since none of the others are of use to you
KyleMCSE
I am currently trying to do this with our water system. around 8000 valves are claimed to not be snapped into the geometric network. I hope that in the 8 years since this comment that you may have figured it out.
Kyle Waun
GIS Technician
WesMiller
Have a look at What are geometric networks?—Help | ArcGIS for Desktop  these are designed for utilities. You may also be interested in The Local Government Information Model—Help | ArcGIS for Desktop.​ The easy way to find valves intersecting lines is a select by location, not fool proof but would give you an idea.
ReneeGerasimtchouk
I did create a geometric network, but needed to snap valves automatically instead of one by one and I was trying to do this inside SQL Server rather then having to export to geodatabase for the network.
Renee,
ReneeGerasimtchouk
Interesting...I tried the SNAP yesterday and got an "ERROR 000800 The value is not a member of END I VERTEX I EDGE" so I thought it wouldn't work. I went ahead and filled in the TYPE and DISTANCE and ran the tool anyway and it seemed to work...don't know why the "ERROR" message was shown. Thank you !
