CANT DELETE FEATURE CLASS FROM GDB IN ARCCATALOG IF WAS ONCE IN CURRENTLY OPEN ARCMAP
858
07-12-2011 05:33 AM
AaronKing
If I have a File gdb feature class in ARCMap, then remove it, then go to delete or rename it in ARCCatalog, I get an error.
If this is not just my own failure to change some arcane setting, then it is a fundamental flaw in the functionality of the File gdb.  I need to clean up my geodatabase, or rename something, many times a day.  I like the functionality of the new fgdb, and I use the Default fgdb function on every map document, but if I have to close ARCMap every time I need to change a name or delete a feature class, then it is a net loss of time and increase of stress.
Anyone know if there is something I can do to avoid this hair-graying ARCfail?
JonathanNorred
Check out the Clear Workspace Cache tool...
