Cannot register an Oracle view with SDE
4993
10
11-16-2012 10:36 AM
ScottSugden
Environment: Windows Server 2008 R2 Standard, Oracle 11g, ArcGisServer 10.1 SP1
Issue: Cannot register an Oracle view with SDE
If I create an Oracle view using an existing/working feature class called Districts using the following syntax:
CREATE OR REPLACE VIEW DISTRICTS2 As
SELECT "TAG","OBJECTID","SHAPE"
FROM Districts
Where ObjectID = 1;
Spatial column is 'Shape'. ID column is 'ObjectId'.
If I then try to register that view with the geodatabase using the following:
sdelayer -o register -l DISTRICTS2,SHAPE -e nac+ -t ST_GEOMETRY -C OBJECTID,USER -i sde:oracle11g:orcl10 -u xxx -p xxx
(-u xxx -p xxx are dummy values)
I get:
Wrong column type (-144)
SE_table_get_shape_type failed.
I have checked the shape column type on the base table DISTRICTS using:
sdelayer -o describe_long -l DISTRICTS,SHAPE -i sde:oracle11g:orcl10 -u xxx -p xxx
And I get:
Spatial Column = SHAPE
Layer Type = ST_GEOMETRY
Entities = nac+
What I am doing wrong?
I cannot use catalog to register the view as the 'Register with geodatabase' option under 'Manage' is greyed out.
I can 'manually' register the view by manually inserting records into the sde tables LAYERS, GEOMETRY_COLUMNS and TABLE_REGISTRY. Obviously this is not the correct way to go!
Thanks in advance.
VinceAngelo
Esri Esteemed Contributor
I found that if I specified the SRID (-R nn) I was able to get the layer to register.
- V
ScottSugden
Perfect! Works like a charm. Many thanks for the help.
CarlosHenrique_Dourado
Hi!
I'm having the same problem but with a different error code
I tried so:
sdelayer -o register -l BAIRROS,SHAPE -e a -C OBJECTID -t SDO_GEOMETRY -P BASIC -u xxx -p xxx
I get:
Error: Wrong column type (-114).
Error: SE_table_get_shape_type failed
Anybody?
VinceAngelo
Please post all relevant information about your environment:
EXACT Oracle release (A.B.C.D.E notation)
EXACT ArcGIS release (version & SP)
EXACT ArcSDE release (version & SP)
The contents of USER_SDO_GEOM_METADATA
DESCRIBE output on the view
'sdetable -o describe' output on the view
Note that "-P BASIC" is no longer a valid  option -- As of 10.1, all native geometries
are always registered with HIGH precision.  You should always register polygons as
multi-part ("a+").  You should always specify coordinate reference parameters
when you register a table (-R or -G/-x).
- V
Enviroment:
Windows 2008 Server Enterprise 64 bits
oracle 11.2.0.3
arcgis desktop 10.1
arcsde 10.1 for oracle 11g
SQL> select table_name, column_name, srid  from user_sdo_GEOM_metadata where table_name='BAIRROS';
TABLE_NAME COLUMN_NAME                          SRID
BAIRROS    SHAPE                               29191
SQL> select  index_name, table_name, column_name  from user_sdo_index_info where table_name='BAIRROS';
INDEX_NAME             TABLE_NAME      COLUMN_NAME
IDXR__BAIBAIR1         BAIRROS          SHAPE
>sdelayer -o register -l BAIRROS,SHAPE -e a -C OBJECTID -t SDO_GEOMETRY  -u xxx -p xxx
ArcSDE 10.1  for Oracle11g Build 679 Thu Apr  5 11:43:21  2012
Layer    Administration Utility
Note that same without  '-P BASIC' returns the same error
VinceAngelo
You should always register polygons as multi-part ("a+").  You should always specify
coordinate reference parameters when you register a table (-R or -G/-x).
- V
sdetable -o describe output
Table BAIRROS:
Column name             Attribute type   Null?      Length,DPs    RowID Column?
ID_BAIRRO               SE_FLOAT64       NULL           38,8
DATA                    SE_DATE          NULL            0
SHAPE                   SE_SHAPE         NULL         2000
COD_BAIRRO              SE_STRING        NULL           10
OBJECTID                SE_INT32         NOT NULL       10
NOMES_BAIRROS           SE_STRING        NULL          200
ESCALA                  SE_STRING        NULL           30
PROJETO                 SE_STRING        NULL          100
FONTE                   SE_STRING        NULL          200
ORIGEM                  SE_STRING        NULL          200
FASE                    SE_STRING        NULL          100
CONTROLE_1              SE_STRING        NULL          100
CONTROLE_2              SE_STRING        NULL          100
CONTROLE_3              SE_STRING        NULL          100
Thanks vangelo
I Got it! Register layer works here.
- V
Multi-part is valid for others geometry types as point and line?
