Cannot open Attachment Manager in Editiing Mode
4850
01-28-2013 10:49 PM
AndreGrosse-Stoltenberg
We want to add photos to our feature classes. We added attachments in ArcCatalog. When we start the editing mode, and select a feature, we cannot open the Attachment manager:
The paper clip icon Open Attachments Manager just above the grid of attribute values does not appear.
When we right-click the the feature, "Open Attachment Manager" stays grey, and we cannot select it.
Anybody knows why we cannot open the Attachment manager?
Thanks!
RudyCharlot
The file in which you are using for the attachment where is it located? Keep in mind, in order for attachment to work correctly  the files have to be resided inside a Geodatabase. I hope I understood your question.
Best regards,
Rudy Charlot
MichaelVolz
Esteemed Contributor
What version of ArcGIS are you working in where the Attachment Manager will not open?
NidhinKarthikeyan
Honored Contributor
Thanks!
The tools in the Attachments toolset require an ArcGIS for Desktop Standard or Advanced license. Also make sure the attached files/data is stored in Geodatabase 10.0 or >. It shouldn't be prior 10.0 Geodatabase.
TuridBrox
This might not solve your problem, but make sure you don't try to open the attachment manager from the _ATTACH-table, but from the original feature class/table.
