Can you tell me why the address locator isn't working?
2757
11
01-24-2019 11:20 AM
Athens_CityPlanner
I have about 4000 addresses, formatted for geocoding.
I created a Dual Range address locator using a line file from the county GIS. Arc autofilled all relevant fields.
I set "match without zones" to YES (I did this after troubleshooting and finding the thread from 2016 indicating that this may solve the problem.)
Geocoding still returns 0 matches.
If I build a point based address locator using the address file from the county GIS, it matches about 1800 addresses.
Where am I goofing?
MichaelVolz
Esteemed Contributor
Can you provide a screenshot of what Arc autofilled?
Are the fields chosen for House From Left, House To Left, House From Right, House To Right all numeric?
Athens_CityPlanner
those are field type long
BillFox
MVP Notable Contributor
Try the rematch button a couple times, any better?
JoeBorgione
How about screen shots of:
An address you expected to resolve
The Attribute table record of the street it should match
Athens_CityPlanner
let's use 12 Fort
Locator:
JoeBorgione
Your address is missing the type of 'ST' where as your matching data (I assume your centerlines) has it.  That should have hit but with a lower score than 100; maybe 80 to 85.  How do you have your scores set up in the actual locator?
Athens_CityPlanner
ShanaBritt
It would be interesting to see what is returned for the '12 Fort Athens 45701' address when using the Find tool with the "show all candidates" option checked. I've often used the Find tool to help see what candidates are returned and what the attributes are of the candidates and their scores. This can help with adjusting the Geocoding options that Joe Borgione‌ pointed out above.
Athens_CityPlanner
the locate tool or something different?
