Can't write feature classes to Linux samba share
13092
20
01-06-2015 01:41 PM
ScottStopyak
Hi all,
I'm trying to write feature classes to a file gdb on a samba share (linux mint). I can create a file geodatabase and a feature dataset, but i can't import a feature class to it. It always throws an error 000210 which says it has invalid arguments and can't aquire a lock. I  can write anything else I want in the share: shapefiles, documents, geodatabases etc. The permissions appear to be wide open read and write for everyone.
Tags (3)
VinceAngelo
Esri Esteemed Contributor
(Moved this discussion from File Geodatabase API)
I would note that avoiding network shares is best practice in file geodatabase use (ALL network shares, including NFS).  Samba is a particularly slow implementation.
- V
LanceShipman
Is this in general or through the File Geodatabase API? What version of ArcGIS? Linux? Samba?
ScottStopyak
In general. You can create a file gdb in a samba share and it will have some functionality but you can’t import to it or do anything that creates a schema lock. I think locks get written and then can’t be unwritten regardless of permissions and such. I’ve long since given up on the file gdb and moved on to using postgres on that box. That was really painful to implement but it works.
ScottStopyak
Xubuntu 14.04 (doesn’t work in CentOS either), samba 2:4.1.6+dfsg-1ubuntu2.14.04.7, 10.2.2 or 10.3
FilipKrál
I created a file geodatabase on our shared samba drive with ArcGIS 10.1. Then I created a polygon feature class in the geodatabse, added some columns and edited a polygon feature. In the end I deleted the whole geodatabase again from ArcCatalog window in ArcMap.
The only problem I encountered what that it was very slow to respond (perhaps due to network speed) but eventually everything worked fine. I cannot tell you any details about our samba setup though.
Filip.
ScottStopyak
Filip,
Can you import or copy in a feature class from elsewhere? I can create things too (file gdb, feature class in that file gdb) but feature class to feature class bombs every time.
FilipKrál
Hi Scott,
Yes, I can import or copy feature classes successfully.
Can it be something about your privileges on the drive you are trying to write to?
The `ls -l` command shows me that I am the owner and that I can do the following with the .gdb folder on samba:
drwxr-x---
and I can do the following with the files in the geodatabase folder:
-rw-r-----
I can even see the .lock files when ArcMap session is using some data from there and the lock files disappear when I close ArcMap.
F.
ScottStopyak
On my samba folder, I did a chmod –R 777. I can read and write anything other than a file gdb from an external source (like another geodatabase on a different server). Do you have any special parameters set in smb.conf for that share or globally? You’re using 10.1 right? I’m on 10.3. Could be a difference maybe?
FilipKrál
Hi Scott, I know very little about samba drives so I'm not able to tell you whether there is anything special about our configuration, sorry.
F.
ScottStopyak
Here’s what I get. See pdf.
