Can't Geocode in ModelBuilder 9.3
936
09-30-2011 06:20 AM
ArjunRattan
I created a model to geocode a subset of a dbf table. The user creates the subset (which is exported as a dbf table as well). The model is simple and follows the structure:
Table Select (<Table 1 is input>, SQL expression is parameter) ---> Geocode Addresses
Every time I run the model, the dbf subset is created but fails on the Geocoding step. I get the error:
ERROR 000010: Geocode addresses failed.
Failed to execute (Geocode Addresses).
I am able to geocode the subset dbf in ArcCatalog (using the same address locator as the Model). I have read the other posts on this topic and they don't solve this problem.
Any suggestions would be greatly appreciated! I am using ArcGIS 9.3.1 (ArcInfo) with ModelBuilder 9.3
Regards,
Arjun Rattan
GIS Planning Assistant
Halton Region
Ontario, Canada
