Can't add GeoEye-1 raster data to a mosaic dataset
1949
03-28-2014 06:04 AM
ShaneBrennan
Hello,
When I try to add rasters to an empty mosaic dataset using the GeoEye-1 raster type, it fails with Error:8004205f: No new mosaic dataset item was added. However, I can add a single .pvl file to ArcMap just fine. I am using 10.2. The empty mosaic dataset was created using default values (i.e. no Product type).
EDIT: The directory and imagery is not read-only
AllisonRost
Hi Shane.
You may be hitting a new known issue:
NIM101221:  The GeoEye-1 raster type does not ingest into a mosaic dataset as a result of new metadata standards.
I would suggest you contact Esri Support to confirm.  This is resolved in 10.3.
AllisonRost
