Can I restrict ArcMap editing by other staff members?
4050
02-27-2015 10:18 AM
deleted-user-eecV1RPyUfl1
We have several staff members who want to build their own projects using ArcMap, but we don't want to provide them edit capabilities.  Can this be simply done with read-only file restrictions etc., or is there a best practice method for doing this?  Thank you!
JakeSkinner
Esri Esteemed Contributor
Hi Dan,
If the data is a shapefile or a File Geodatabase Feature Class, yes you can simply apply read-only access to the directory and the user will not be able to edit the data.
JakeSkinner
Hi Dan,
Thank you very much for the quick response Jake!  We are using primarily File GDBs, so that's how we'll handle it for now.  Thanks again.  -Dan
