select owner, object_type, count(*) from dba_objects where owner = 'SDE' and object_type like '%TYPE%' group by owner, object_type order by object_type; OWNER OBJECT_TYPE COUNT(*) ------------------------------ ------------------- ---------- SDE INDEXTYPE 1 SDE TYPE 39 SDE TYPE BODY 24
OWNER OBJECT_TYPE OBJECT_NAME SUBOBJECT_NAME STATUS ------------------------------ ------------------- ------------------------------ ----------------------------- SDE TYPE ST_DOMAIN_METHODS $VSN_4 VALID SDE TYPE ST_DOMAIN_METHODS $VSN_3 VALID SDE TYPE ST_DOMAIN_METHODS $VSN_2 VALID SDE TYPE ST_DOMAIN_METHODS $VSN_5 VALID SDE TYPE ST_DOMAIN_METHODS $VSN_1 VALID SDE TYPE ST_DOMAIN_STATS $VSN_3 VALID SDE TYPE ST_DOMAIN_STATS $VSN_2 VALID SDE TYPE ST_DOMAIN_STATS $VSN_1 VALID
Our service request with Oracle is not providing workarounds, tips or solutions for working with SDE to avoid the data dictionary corruption or avoiding the breakage of Data Pump. We have just rebuilt SDE manually in another database so have a good export to try importing into another working instance, hopefully not breaking Data Pump and keeping the d.d. intact and no missing ST_GEOMETRY data types. I have just completed a support call to ESRI for their help. I will keep you updated.
Jane
ORA-39127: error inesperado de la llamada a local_str := SYS.DBMS_EXPORT_EXTENSION.GET_DOMAIN_INDEX_METADATA('<index_name>','<schema_name>','ST_DOMAIN_METHODS','<schema_name>',11.02.00.00.00,newblock,0) ORA-06502: PL/SQL: error : character to number conversion error numérico o de valor ORA-06512: en "SYS.DBMS_EXPORT_EXTENSION", línea 270 ORA-06512: en línea 1 ORA-06512: en "SYS.DBMS_METADATA", línea 8360
KUP-11007: conversion error loading table "<schema>"."<feature_class>" ORA-00600: internal error code, arguments: [kpudpxcs_ctxConvertStream_ref_1], [SYS_TYPEID("SHAPE")], [], [], [], [], [], [], [], [], [], [] ORA-31693: Fallo del objeto de datos de tabla "<schema>"."<feature_class>" al cargarse/descargarse y se está saltando debido al error: ORA-29913: error al ejecutar la llamada de ODCIEXTTABLEFETCH ORA-26062: No se puede continuar desde los errores anteriores.
Hi all,
I am new to ESRI. We have just configured a geodatabase in our 11.2.0.3 Oracle database and have the same problem as you. If we perform a expdp of SDE schema we get an error. We are using arcSDE 10.
We only have one schema using the ST_GEOMETRY datatype, the one containing the SDE objects.ORA-39127: error inesperado de la llamada a local_str := SYS.DBMS_EXPORT_EXTENSION.GET_DOMAIN_INDEX_METADATA('<index_name>','<schema_name>','ST_DOMAIN_METHODS','<schema_name>',11.02.00.00.00,newblock,0) ORA-06502: PL/SQL: error : character to number conversion error numérico o de valor ORA-06512: en "SYS.DBMS_EXPORT_EXTENSION", línea 270 ORA-06512: en línea 1 ORA-06512: en "SYS.DBMS_METADATA", línea 8360
We can get avoid this error droping the index prior to the expdp and recreate it afterwards, but in any case we get a lot of errors when doing an impdp of SDE schema.KUP-11007: conversion error loading table "<schema>"."<feature_class>" ORA-00600: internal error code, arguments: [kpudpxcs_ctxConvertStream_ref_1], [SYS_TYPEID("SHAPE")], [], [], [], [], [], [], [], [], [], [] ORA-31693: Fallo del objeto de datos de tabla "<schema>"."<feature_class>" al cargarse/descargarse y se está saltando debido al error: ORA-29913: error al ejecutar la llamada de ODCIEXTTABLEFETCH ORA-26062: No se puede continuar desde los errores anteriores.
We have an open SR to Oracle without solution so far.
Inaki
Hi Dana,
It sounds like you might be running into an oracle problem with datapump. Check out the following oracle document and bug:
Ora-22809 Nonexistent Attribute Creating Table With Sde.St_geometry Type [ID 1411854.1]
Bug filed with Datapump:
Bug 13693393 - ORA-600: [KPUDPXCS_CTXCONVERTSTREAM_REF_1], [SYS_TYPEID("SHAPE")] DURING IMPORT
