automatic drawed polygons
2124
08-10-2012 09:48 AM
AndreasDaim
hey community!
is it possible to automate polygon drawing on this georeferenced picture?
[ATTACH=CONFIG]16835[/ATTACH]
I want GIS to detect the dark black areas and surround them with a polygon.
best regards
hagen
PetronilaMandeno
Well, one thing you can do is use the Image Analysis tool to sharpen the image and change the contrast so that the Image Classification tool will pick up the features that you want. Then you can, of course, convert the resulting raster into polygons. Once you have the polygons, you can fine tune them with the standard feature editing tools.
Does that help?
PavanYadav
Hi Hagen,
You may want to try Image Classification.
Regards,
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
AndreasDaim
That seems to be the right tool, thanks Pavan.
But i still didn't figure out to get good results.
I am greatful for hints to maximize results of this image with image classification.
best regards!
hagen
PetronilaMandeno
Does that help?
AndreasDaim
i didnt figure out, how to sharpen the image or did i use the wrong tool?
can u pls describe the sharpen process step by step?
AndreasDaim
i managed work with the image analysis - thanks!
didnt get the results at the moment i want to but still trying on. perhaps it's neccesary to edit this difficult images in photoshop before arcgis use.
i'll write again after checking out the best solution.
best regards
andreas
