Auto choose Geographic transformation
1792
02-20-2017 02:00 PM
AbdullahAnter
Honored Contributor
I have a problem when I try to use Project tool.
when I try to reproject a shape file to other GCS the tool not Auto choose Geographic transformation.
that in using ArcGIS 10.1 . But when I use ArcGIS 10.2.2 and with same GCS it auto choose the appropriate geographic transformation.
AbdullahAnter
Honored Contributor
It is the first time for me to know that , if the data frame has unknown spatial reference disable Auto choose Geographic transformation in Project tool.
DanPatterson_Retired
That is a ways back, you would have to check the help documents for 10.1 and 10.2 to see if it was added between versions.  I don't have the changes list going back as far as 10.1 but the help topics are in this link in the left column
AbdullahAnter
Honored Contributor
