sdelayer -o describe -l TESTLAYER,SHAPE -u feed
ArcSDE 9.3.1 for Oracle11g Build 2784 Tue Oct 27 10:51:14 2009
Layer Administration Utility
Table Owner : FEED
Table Name : TESTLAYER
Spatial Column : SHAPE
Layer id : 146
Entities : np+
Layer Type : In-Line Spatial Type
I/O Mode : NORMAL
Autolocking : Disabled
Precision : High
User Privileges : SELECT
Layer Configuration: DEFAULTS
sdelayer -o describe_long -l TESTLAYER,SHAPE -u feed
Layer Description ....: <None>
Table Owner ..........: FEED
Table Name ...........: TESTLAYER
Spatial Column .......: SHAPE
Layer Id .............: 146
SRID .................: 24
Minimum Shape Id .....: 1
Offset ...............:
falsex: -500.000000
falsey: -500.000000
System Units .........: 8000000000000.000000
Z Offset..............: 0.000000
Z Units ..............: 1.000000
Measure Offset .......: <None>
Measure Units ........: <None>
XY Cluster Tolerance .: 0.0000000002
Spatial Index ........:
parameter: SPIDX_RTREE
exist: Yes
array form: -2,0,0
Layer Envelope .......:
minx: -180.00000, miny: -90.00000
maxx: 180.00000, maxy: 90.00000
Entities .............: np+
Layer Type ...........: In-Line Spatial Type
Creation Date ........: Fri May 21 08:14:16 2010
I/O Mode .............: NORMAL
Autolocking ..........: Disabled
Precision.............: High
User Privileges ......: SELECT
Coordinate System ....: GEOGCS["WGS 84",DATUM["World Geodetic System 1984 [EPSG ID 6326]",SPHEROID["WGS 84 [EPSG ID 7030]",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Decimal Degree",0.01745329251994328]]
Layer Configuration ..: DEFAULTS
sdelayer -o stats -l TESTLAYER,SHAPE -u feed
The requested operation is not supported.
sdelayer -o feature_info -l TESTLAYER,SHAPE -u feed -p `decode $FEED`
Row Id,FID,Entity Type,Annotation,Cad Data,Number of Points,Number of Parts,Number of Subparts,Self-Touching Rings,Minimum Precision
1,1,P,F,F,1,1,0,F,High
2,2,P,F,F,1,1,0,F,High
3,3,P,F,F,1,1,0,F,High
4,4,P,F,F,1,1,0,F,High
5,5,P,F,F,1,1,0,F,High
6,6,P,F,F,1,1,0,F,High
7,7,P,F,F,1,1,0,F,High
8,8,P,F,F,1,1,0,F,High
9,9,P,F,F,1,1,0,F,High
10,10,P,F,F,1,1,0,F,High
11,11,P,F,F,1,1,0,F,High
12,12,P,F,F,1,1,0,F,High
13,13,P,F,F,1,1,0,F,High
14,14,P,F,F,1,1,0,F,High
15,15,P,F,F,1,1,0,F,High
16,16,P,F,F,1,1,0,F,High
17,17,P,F,F,1,1,0,F,High
18,18,P,F,F,1,1,0,F,High
19,19,P,F,F,1,1,0,F,High
20,20,P,F,F,1,1,0,F,High
21,21,P,F,F,1,1,0,F,High
22,22,P,F,F,1,1,0,F,High
23,23,P,F,F,1,1,0,F,High
24,24,P,F,F,1,1,0,F,High
25,25,P,F,F,1,1,0,F,High
26,26,P,F,F,1,1,0,F,High
Total rows examined: 26
Total invalid shapes: 0
