ArcSDE locking feature dataset
927
09-19-2012 04:41 AM
BarryGuidry
We have recently upgraded to ArcSDE / Desktops 10 SP5, in addition to moving ArcSDE to another server, along with ArcGIS Server 10 SP5. Our database is Oracle 11g. We have confirmed that the permissions on the database are correct. Occassionally, ArcSDE will lock a feature dataset, and need to be restarted.
Is there anything we can check to see why this may be happening?
OK. I think I know why this is happening now. It appears, based on the feature datasets' feature class contents, that my ArcGIS Server map service is locking them. So, I guess it is necessary to stop all map services in order to change the schema of data within a locked feature dataset.
JoeBorgione
Barry-  just one of the many reasons why I don't like using feature datasets in a SDE database.  They just don't play well together at a number of levels....
Glad you figured it out your problem though!
That should just about do it....
BarryGuidry
Thanks, Joe. Not much of a problem, now that I understand it 😮
I'll simply send out a systemwide message when I need to make a schema edit, and do it after hours 🙂
