ArcSDE 10 install RHEL 5.4 64bit sdesetup missing libraries libXm.so.3 etc.
2535
5
08-13-2010 05:46 AM
ChristopherLott
I am installing ESRI ArcSDE 10 on a newly installed Red Hat Enterprise Linux
5.4 64bit machine.  I'm trying to meet the installation requirements to the letter!
Unfortunately the sdesetup program has dependencies
on libraries that are not installed by default in RHEL5.4.  The libraries
required are libXm.so.3 and libg2c.so.0.  The file libXm.so.3 is
provided by package openmotif22-2.2.3-18.x86_64.rpm; the file
libg2c.so.0 is provided by package compat-libf2c-34-3.4.6-4.x86_64.rpm.
The openmotif22 package in turn requires library libXp.so.6 which is
provided by package libXp-1.0.0-8.1.el5.x86_64.rpm.  That was painful,
but I got thru it because all the RPMs are provided on the RHEL 5.4 media.
Here's the same discussion for version 9.3:
http://forums.esri.com/Thread.asp?c=158&f=2285&t=233254
Hey ESRI doc people, would you please please add this!?  Hope this helps someone.
chris...
p.s. error messages are below so google has something to chew on
% sdesetup
sdesetup: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
# rpm -ihv openmotif22-2.2.3-18.x86_64.rpm
warning: openmotif22-2.2.3-18.x86_64.rpm: Header V3 DSA signature: NOKEY, key ID 37017186
error: Failed dependencies:
        libXp.so.6()(64bit) is needed by openmotif22-2.2.3-18.x86_64
% sdesetup
sdesetup: error while loading shared libraries: libg2c.so.0: cannot open shared object file: No such file or directory
ThomasBaker
I'm trying to install SDE 10 on RHEL 5.5/Oracle 11G and am having problems. Everything seems to install fine but connecting with arccatalog from a Windows box after installation I get this error:
Failed to connect to the specified server.
This release of GeoDatabase is either invalid or out of date. [Please
run the ArcSDE setup utility using the -o install option.]
DBMS table not found [ORA-00942: table or view does not
exist][SDE.GDB_Release]
There are warnings in the sde_setup.log but it seems they are only warnings and the installation chugs along:
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "XMLDB_INDEX_FULLTEXT" not found in keyword "DEFAULTS".
  Inserting the default values.
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "XMLDB_INDEX_TAG" not found in keyword "DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_AREA" not found in keyword "NETWORK_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_FID" not found in keyword "NETWORK_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_LEN" not found in keyword "NETWORK_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_STORAGE" not found in keyword "NETWORK_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "S_INDEX_SP_FID" not found in keyword "NETWORK_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_AREA" not found in keyword "TOPOLOGY_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_FID" not found in keyword "TOPOLOGY_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_LEN" not found in keyword "TOPOLOGY_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_STORAGE" not found in keyword "TOPOLOGY_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "S_INDEX_SP_FID" not found in keyword "TOPOLOGY_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_AREA" not found in keyword "TOPOLOGY_DEFAULTS::DIRTYAREAS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_FID" not found in keyword "TOPOLOGY_DEFAULTS::DIRTYAREAS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_LEN" not found in keyword "TOPOLOGY_DEFAULTS::DIRTYAREAS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_STORAGE" not found in keyword "TOPOLOGY_DEFAULTS::DIRTYAREAS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "S_INDEX_SP_FID" not found in keyword "TOPOLOGY_DEFAULTS::DIRTYAREAS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_AREA" not found in keyword "TERRAIN_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_FID" not found in keyword "TERRAIN_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_LEN" not found in keyword "TERRAIN_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_STORAGE" not found in keyword "TERRAIN_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "S_INDEX_SP_FID" not found in keyword "TERRAIN_DEFAULTS".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_AREA" not found in keyword "TERRAIN_DEFAULTS::EMBEDDED".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_FID" not found in keyword "TERRAIN_DEFAULTS::EMBEDDED".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_INDEX_LEN" not found in keyword "TERRAIN_DEFAULTS::EMBEDDED".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "F_STORAGE" not found in keyword "TERRAIN_DEFAULTS::EMBEDDED".
[Thu Sep 30 13:50:58 2010] WARNING: Config parameter "S_INDEX_SP_FID" not found in keyword "TERRAIN_DEFAULTS::EMBEDDED".
[Thu Sep 30 13:50:59 2010]
The log file ends with this:
[Thu Sep 30 13:51:13 2010] St_Geometry type created or updated...
[Thu Sep 30 13:51:14 2010]
ST_Geometry Schema Owner: (SDE) Type Release: 1007
[Thu Sep 30 13:51:14 2010] Instance initialized for ((sde)) . . .
[Thu Sep 30 13:51:14 2010] Successfully created  GDB_Tables_Last_Modified table...
[Thu Sep 30 13:51:16 2010] Successfully created  GDB_Items table...
[Thu Sep 30 13:51:16 2010] Successfully created  GDB_ItemRelationships table...
[Thu Sep 30 13:51:16 2010] Successfully created  GDB_ItemTypes table...
[Thu Sep 30 13:51:16 2010] Successfully created  GDB_ItemRelationshipTypes table...
[Thu Sep 30 13:51:16 2010] Successfully created  GDB_ReplicaLog table...
Is there anything missing from the install procedure that might be overlooked by a nube?
VinceAngelo
Esri Esteemed Contributor
Those are 'sdesetup' messages, consistent with the expected output of a fresh install,
not something 'gsrvr' would generate. If you used Direct Connect from ArcGIS, the
error logs would be on the Desktop box, not the server.
- V
VinceAngelo
What ArcGIS client are you using?  Only ArcGIS 10.0 clients can connect to a 10.0 ArcSDE server.
- V
ThomasBaker
Thanks. Not having ARCGis 10.0 was the problem. After updating, it worked fine.
RayburnClipper
Thanks for posting this Chris, I was just googling the issue and got your post!  Now I need to find the RPMs and install, I hope it goes well for me. LOL
Government - If you think the problems we create are bad, just wait until you see our solutions.
