ArcGIS Pro at 2.4/arcpy- FeatureClassToFeatureClass_conversion does not honor overwriteOutput env setting
5126
11
08-07-2019 07:35 AM
DavidColey
MVP Frequent Contributor
Hello - I upgraded to Pro to 2.4 yesterday and lo and behold my python scripts for overwriting feature classes using the FeatureClassToFeatureClass_conversion tool no longer honors the arcpy.env.overwriteOutput = True environment setting.
A whole bunch of my data management scripts depend on this!
The script now keeps telling me that my feature class already exists.  Of course it does, I'm doing an overwrite.  Or at least I did.
This was working just fine at 2.1, 2.2, 2.3.x
I can't use Copy for most of my layers because I don't want bring over (in some cases) dozens of related tables....
Example:
# Import system modules
import sys, os, arcpy, time, smtplib
from datetime import date, timedelta
from arcpy import env
# Local variables...
message = ""
current_time = time.asctime()
todaysDate = date.today()
priorYear = str(todaysDate - timedelta(days=547)) #547
starting_time = time.time()
arcpy.SetLogHistory(False)
arcpy.env.configKeyword= "DEFAULTS"
arcpy.env.maintainAttachments = False
try:
 env.workspace = r"\\scggisis01pw\\agsfed\\data-store\\VantagePoint\\Data" #\\scggisis01pw\\agsfed
 coordinate_system = r"C:\\StageDbsAE\\CoordinateSystems.gdb\\WebMercator"
 env.outputCoordinateSystem = coordinate_system
 env.geographicTransformations = "NAD_1983_HARN_To_WGS_1984_2"
 for fc in arcpy.ListFeatureClasses():
 outLocation = r"\\scggisis01pw\\agsfed\\data-store\\VantagePoint\\Data\\VpAnno.gdb\\VantagePointLayers" # VantagePoint.gdb\
 outFC = fc[:-4] #neg slice for shapes, 4 from right
 #if outFC != "UtilityBilling":
 print (outLocation + "\\" + outFC)
 #disableFC = outLocation + "\\" + outFC
 arcpy.FeatureClassToFeatureClass_conversion(fc, outLocation, outFC)
 message = message + "\n" + "Added Features: " + outFC
 #arcpy.RemoveSpatialIndex_management(disableFC)
 #arcpy.AddSpatialIndex_management(disableFC)
 #message = message + "\n" + "Handeld Indexing: " + disableFC
 #else:
 # pass
except Exception:
 # If an error occurred, print line number and error message
 import traceback, sys
 tb = sys.exc_info()[2]
 e = sys.exc_info()[1]
 #print(e.args[0])
 #print "Line %i" % tb.tb_lineno
 message = message + "\n" + "Line %i" % tb.tb_lineno
 message = message + "\n" + str(e)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
BryanLiu
I have the same problem.
sys.executable
'C:\\Users\\myname\\AppData\\Local\\ESRI\\conda\\envs\\myenv\\python.exe'
arcpy.__path__
['C:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcPy\\arcpy']
How did you fix it? Thanks.
DavidColey
This never did get fixed.  The solution is to delete the feature classes first.
