ArcGIS Pro 1.4 Field calculator
1913
04-09-2017 08:45 PM
MatthewIrwin
how do i extract the first character from another field, In desktop i would of used the Left([Field1],1)
JayantaPoddar
Use this python expression:
!fieldname![0]
Think Location
DanPatterson_Retired
But if there is the remotest change that you will have nulls in your table, then you have to go with a bit more pythonic magic which basically does a true/false test.  if the field called 'afield' is None (aka Null) then you take the slice to the right of the selection options.  If it contains text, then you take the slice to the left, which is the false part.
So in short the syntax is [ false section, true section][query]   or [0, 1][query] [False, True][query] useful functionality avoiding code blocks for simple yes/no questions
[!afield![0], None][!afield! is None]
JoshuaBixby
MVP Esteemed Contributor
You can also handle the None/NULL issue using a Python conditional expression, which avoids the need for a code block with simple expressions and follows a classic ternary operator pattern:
None if None else !Field1![0]
