Analyze Feature Class using ArcGIS Pro
1944
02-04-2023 04:23 PM
Labels (3)
yockee
I used to be able to run this geoprocessing using ArcMap 10.5 against Oracle 12 Database :
import arcpy
arcpy.AnalyzeDatasets_management("D:/path_to_connectionfile/dbspatial.sde",
"SYSTEM", ["xxx";"xxx"],"ANALYZE_BASE", "NO_ANALYZE_DELTA", "NO_ANALYZE_ARCHIVE")
Now the database has been upgraded to Oracle 19 and I can not connect to geodatabase anymore using ArcMap 10.6. The only way I can connect is by using ArcGIS Pro. But I am very unfamiliar with its layout. I want to do the geoprocessing above or may be there are any equivalent format to achieve the same thing.
I can connect to the geodatabase just fine but I just have not find a way to run that geoprocessing.
Need your help and advice
JayantaPoddar
MVP Alum
Oracle 19C is supported from ArcGIS 10.6.1 with ArcGIS (Desktop, Engine, Server) Support for Oracle 19c Patch .
Oracle database requirements for ArcGIS 10.6.x
Think Location
yockee
Hi, sorry I was wrong. It turns out that I have ArcMAP 10.5.
so, how do I run that piece of code on ArcGIS Pro ?
MarceloMarques
Analyze (Data Management)—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
