Append (Data Management GP tool) - Why the extreme speed difference between SQL Server and Local File geodatabase
5566
8
02-14-2023 12:36 PM
Labels (3)
DavidSchuster
Hello Community!
I need help understanding how the Append tool (data management) works, and why the performance is vastly different if I use a target feature class on SQL server versus a target feature class in a local file geodatabase.
I have a geoprocessing task that I developed in Model Builder.  As the last step of my task, I append a small number of features (less than 30 usually) into a feature class containing a very large number of rows (1 million or so), but it is taking a very long time.  I simply need to save the rows and exit the task.  In other words, I don't need to access the updated feature class after the append is complete.
To troubleshoot, I created a test geoprocessing tool that does two tests:
Test 1 - Append 30 rows into a SQL Server feature class containing 1 million rows.  This takes 53 seconds to complete the task, however I noticed that if I select from the table, I can see the rows are immediately inserted into the database.  If the data has been inserted, what is the append operation doing the rest of the time?
Test 2 - Append 30 rows into a File Geodatabase feature class containing 1 million rows.  This only takes 1 second to complete.
What am I doing wrong?  Are there things that I can check on SQL Server to troubleshoot the issue?
Thank you!
David
A screenshot of my test model is shown below.
DavidSchuster
Thanks to George and his SDE intercept tip, SQL Profiler, and the help of a couple of my colleagues, we finally found the problem!
I realize now that I should have mentioned that we run our tool very frequently.  And I also wasn't aware of this hidden danger:
Inside of the GDB_Items table managed by SDE, there is a Documentation column containing an XML document that contains the history of geoprocessing operations performed on the feature class in question.  Every time our tool ran and appended rows, it added a block of logging XML to that feature class's history.  The XML document for that feature class had grown to over 45MB, making further logging updates painfully slow!
Here's an article that talks more about this:  Geoprocessing history logging in ArcGIS: performance review – Alex Tereshenkov (wordpress.com)
So the solution in our case is to turn this logging history off for our geoprocessing task, to ensure that we aren't writing geoprocessing operations to the dataset metadata.
arcpy.SetLogHistory(false)
correction... I think this is the function we need to call:  arcpy.SetLogMetadata(False).
or in the ArcPro settings:
Perhaps ArcPro / ModelBuilder could be enhanced in some way to make this behavior more obvious?  I didn't see anything about this potential problem when looking through the Environment Variables, on the [Append] Tool settings, or anywhere in the Publish tool settings when I publish my geoprocessing task.  Also, it seems like it would be more performant for the metadata / history be stored differently, perhaps in a linked table rather than an XML document, in order to make these logging history updates faster.  Just my two cents.
Thank you again for your assistance!
-David
ClaudioRuschel
The problem is that to connect to SQL Server there are many "handshaking" operations that are not necessary for a local FGDB connection. The operation to insert 30 rows is quite simple, but to carry it out, many messages are exchanged between the client and the server that slow down the process.
MarceloMarques
@ClaudioRuschel - read my white paper.
commnity.esri.com - How Load Large Featureclass SQL Server Geodatabase
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
George_Thompson
Esri Notable Contributor
You can run a SQL trace in SQL Server and look at all the operations being completed during the append process. This will tell you where the time is spent. You can also do an SDEINTERCEPT (https://support.esri.com/en/technical-article/000014807) on ArcGIS Pro at the same time which can be used to compare where the time is spent: client (ArcGIS Pro) or SQL Server.
I wonder if some of the time is updating indexes, which is not an ArcGIS "task".
If you run the GP tool (not in model builder) does it have different run times?
--- George T.
DavidSchuster
Hi George,
Thanks for the tips on the SdeIntercept.  I was struggling to get SQL Profiler to return something useful.
I ran my test again with sde intercept enabled and looked through the logs.  I see the process doing the TableInsert and FlushBufferedWrites within the first few seconds to insert the rows.  But after that step, I see a lot of other entries in the log, including several ExecuteSpatialQuery calls like this:
Each of these takes on average 10 seconds.  I'm not really sure why it is executing these spatial queries, because they aren't part of my model.  Can you help me figure this out?
p.s. I do not see any log entries related to dropping or creating the spatial indexes (e.g. TableCreateSpatialIndexWithInfo / TableDropSpatialIndex) because I set the MaintainSpatialIndex environment variable in the Environment properties before running my test.
Thank you
David
George_Thompson
You would need to compare to the SQL trace to the SDE intercept to see what SQL Server is doing at the same time. It could be on the SQL side and the ArcGIS client is "waiting" for something back.
It would be best to work with technical support on this issue. They can help you dive deeper into the issue.
--- George T.
DavidSchuster
Thanks George, I will reach out to support.  I appreciate the info you provided.
-David
DavidSchuster
-David
George_Thompson
That is a great find, I know about the issue but did not think about it in this case.
That should help speed up the process.
--- George T.
