Analyze Datasets tool - Datasets to Analyze maintenance
6573
12
05-21-2024 01:35 PM
AndreaB_
Hi all,
I'm looking into using the Analyze Datasets tool in ArcGIS Pro. Couple questions:
1) Is there a way to pick all Datasets in the geodatabase? Would be nice if we had a select all button here - I have a lot and I haven't picked them all from the drop down yet. I think you all are going to say - use Python. and I'm sure I should but I really just wanted a quick way to run this tool on all datasets.
2) I see Only datasets that are owned by the connected user will be displayed.  So do people end up running this tool at least twice - once as 'sde' and once as the DataOwner user?
Andrea
MarceloMarques
@AndreaB_ - grant db_owner role to the sde user on the geodatabase that has the sde user as the data owner user, close/open ArcGIS Pro and then try again the Analyze Tool using the connection file of the sde user and it shall work this time.
Tip: You can update statistics directly in SQL Server using this SQL command.
USE <your_db_name_here>
GO
EXEC sp_updatestats
GO
https://learn.microsoft.com/en-us/sql/relational-databases/system-stored-procedures/sp-updatestats-t...
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
AndreaB_
Hi @MarceloMarques ,
So I tested giving db_owner role to sde user on that old geodatabase. It still didn't allow me to have permissions to run the Analyze Tool. I think there are other things going on with that geodatabase. But no worries - because I tested the Analyze Tool on my new and improved sql geodatabase using the Data Owner connection and it worked perfectly. My goal is to replace the old geodatabase and the sooner the better.
Oh, and I'm not dbo or sysadmin so I can't update statistics directly in SQL Server using that SQL command. Wish I could. I'm a member of db_owner but that didn't seem to matter.
Thanks again.
MarceloMarques
@AndreaB_ - I am glad that the new SQL Server Geodatabase that you created following the best practices is working smoothly. That is the goal of my database template scripts and database guidebooks. I am happy is helping.  : )
Mapping and Charting Solutions (MCS) Enterprise Databases Best Practices (esri.com)
