Address Geocoding locator for 'US Dual Range Addresses' does not work in 10.2.1.
5600
02-25-2014 05:54 AM
SrijanaTuladhar
Address Geocoding locator for 'US Dual Range Addresses' does not work in 10.2.1. This worked for us in 9.3 version with 'US Streets' locator style, I know the locator style name has changed in 10.2.1. Is there something different in 10.2.1 that we needed to set up for the dual range addresses? Or Is this a bug? Thanks in an advance for your help.
TimWitt
Is nothing working or certain features are not working?
SrijanaTuladhar
It does not geocode any addresses when we use this locator. So nothing working..
SrijanaTuladhar
The problem has been resolved after performing following steps:
1) Right Click on the address locator > Click Properties >
2) In the geocoding options section change "Match with no zones" from "no" to "yes"
SrihariManepalli
Changing geocoding properties as mentioned above returned results.
ShanaBritt
Srijana,
The following technical article provides a permanent solution.
40678 - Dual Ranges address locators created with ArcGIS for Desktop 10.1 and higher do not return m...
You should also find my response in the following thread helpful as well.
Re: Geocoding -- 10 vs 10.1
-Shana
