Hey all! First post on here, I figured this would be the place to go.
I have ArcGIS 10.x and I was wondering is there a way to add text to a layer so that the text could be clicked on/off like a layer and be locked at a specific point? For example I understand you can add text to the layout view; but as soon as you resize or move the map the text does not move with it. Is there a way in data view to add text to a layer and have it move with with the layer as you move it? This is probably a simple answer. Thanks a lot! (If you can provide sort of step by step instructions that would be fantastic).
