Adding RADARSAT-2 data to a mosaic dataset - Error: 8004205f
1093
10-20-2013 07:16 PM
AntonSizo
I tried to add a RADARSAT-2 SLC data to a mosaic dataset following Adding RADARSAT-2 data to a mosaic dataset instruction (http://resources.arcgis.com/en/help/main/10.2/index.html#//009t000001zz000000).
Settings: Polarization Type: HH; Radiometric Calibration: Sigma-nought.
But I received
Error: 8004205f: No new mosaic dataset item was added.
Any ideas where can I find a description of that error? Or any examples how to add a Radarsat-2 with specific parameters?
It works with default settings, means without radiometric calibration and all polarization bands.
Thanks in advance
NidhinKarthikeyan
Honored Contributor
Anton,
You can try using the "Input Data Filter" option (Filter the grids and remove unwanted grids) , under "Advanced Options" of "Add Rasters To Mosaic Dataset" tool.
Regards,
