A privileges granted to a user for enterprise geodatabase layer,
6795
20
08-06-2014 01:23 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how a user can “see” layers stored in enterprise geodatabase while this user is not granted any privileges.
  1. The access type of the enterprise geodatabase (Q.mdf) is “public”
  1. The “Ali” user is not given any privileges to the “communities” layer
  1. Nevertheless, “Ali” can see the “communities” layer (as the “Q” enterprise database is accessed by Ali)
What might be the issue here?
How Could Ali access the “communities” layer while he has not given any privileges to it?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
Thanks guys for the useful input.
Hi Asrujit,
Could you please try to add a user to an SQL database from the ArcGIS in your environment. Do you have the same behavior?
Hi Sol,
As we add a user to the database from the ArcGIS, there is no option to “revoke”.
Jamal Numan
JamalNUMAN
Thank you Sol. This is useful
Hi Asrujit:
I couldn’t figure out the equivalent tool of the “add user” of the ArcGIS in the SQL server manager?
  I tried the one in the screenshot below but couldn’t find how to apply password
Jamal Numan
AsrujitSengupta
You need to create the new login under Security at the Instance level, not under the Database security.
JamalNUMAN
Thanks Asrujit,
“amjad” has been added, but he can see nothing.
Please, have a look in the screenshot below.
Jamal Numan
AsrujitSengupta
You need to Map "Amjad" to the required database.. using the "User Mapping" option in Login properties..
JamalNUMAN
Hi Asrujit,
Adding a user from the “SQL Server Management Studio” reproduces the same behavior.
As “Amjad” is added from the “SQL Server Management Studio”, he is able to Access and EDIT the content of the Q database (he is given permission and privilege’s in one hit!). The ArcGIS doesn’t show that Amjad is given any privileges; nevertheless, Amjad is able to Access and Edit the data!
What might this indicate for?
Jamal Numan
AsrujitSengupta
Can you list the permissions that shows up for the new user in the database properties.
JamalNUMAN
“Amjad” has only “connect”, nevertheless, he can View and Edit the data!
Jamal Numan
SharonLitteral
We are using Windows Authentication and direct connect to the database.
Yes, they are a member of a lot of nested groups. However, we denied
access through SQL to a single table with a group that contains all domain
users. We then used ArcCatalog and changed privileges for another group
that the user belongs to to allow select. At this stage, we can see the
feature classes in the ArcCatalog tree view, but when we click on any
feature class in the feature dataset, it gives an error message box. The
message states that we have insufficient privileges on the feature class
where we denied access. Our dba has tried removing and adding db security
groups and Active Directory groups with select table granted back to the
single table with the same result. This user does not have a db login but
is a member of several nested groups that can connect to the db.
AsrujitSengupta
Its a bit confusing and maybe taking a look at your configuration will help in clearing things out. How about contacting ESRI Tech-Support...maybe that'll help and be a faster way of troubleshooting this.
