9.3 File Geodatabase object limit for line feature class
4103
06-03-2015 03:16 AM
NaimeCelik
I am trying to add a line feature class into a 9.3 file geodatabase I have 11100 object in it but everytime I export the data, the number of element is being reduced to 11093. if I export it to 10.2 version file geodatabase, I do not have problem. Is there any number limit for 9.3 version? What can be causing this problem?
JakeSkinner
Esri Esteemed Contributor
Hi Naime,
There isn't a limit for the number of features within a File Geodatabase feature class.  I would recommend making a backup of the feature class, and then running the Check Geometry and Repair Geometry tools on the feature class.
JoeBorgione
I agree with Jake; sounds like you might have some empty geometry features.
That should just about do it....
