I recently upgraded a version 10.8.1 enterprise SQL Server geodatabase to version 11 using ArcGIS Pro 3.0 Upgrade Geodatabase GP tool. Doing so, come to find out by design, altered the way the geodatabase items are named. In v11 it no longer uses the [databasename].[schema].[tablename] format and is now only [schema].[tablename]. This change broke all of my enterprise paths in models and python scripts for things like feature class paths, field mapping paths, etc. I wasn't expecting that, and it was a big chore to repair. Please update the documentation to warn of that change when upgrading between geodatabase versions prior to v11.
@TimMinter - if your post was a "question" instead of an "idea" then each reply would have a "kudo" option, an "idea" has only one kudo option at the first post. I am glad to help.
Data Management - Esri Community
Thank you @MarceloMarques! I would also be kudo-ing. This is why I asked Esri to allow us to Kudo comments in Ideas. They said, no. 😊
Have a nice weekend.
Hi @MarceloMarques ,
Can you please tell me where I can find this table that you referenced above?
Can't find it anywhere.
Thank you
see the 10.9.1 ArcGIS Enterprise Help
https://enterprise.arcgis.com/en/server/10.9.1/manage-data/windows/client-geodatabase-compatibility....
the table was removed at newer versions of the help e.g. 11.1 / 11.2 / 11.3 unfortunately.
This may not be exactly what you are looking for, but the following link is very helpful to me.
This applied to upgrade behavior that is now the default in SQL Server geodatabases. It has been documented in What's New, blog posts, and core documentation.
