Range Domain Validation
1010
10-24-2012 03:45 AM
Status: Closed
by Anonymous User
Not applicable
It would be useful if the validation of range domains was "on the fly" rather than having to select all your features and then validate features under the editor toolbar.  Surely the time taken to set up the domain and to then validate is longer than to select by attributes of those invalid range values?
It seems that all the validation does is select those invalid values anyway.
2 Comments
DuncanHornby
All,
Have a look at this page on the ideas site, there is a comment about turning on an "always validate" on table.  This works great if you are in TABLE VIEW mode. But who ever uses that when creating new features in a FeatureClass, especially now in ArcGIS 10 and the new template method?
If you are going to attribute a feature you are going to do it in the Attributes Window accessed from the Editor toolbar. This does not enforce the domain range. So Gemma's idea still stands.
SSWoodward
Status changed to: Closed
In ArcGIS 3.1, Range Domains are validated on the fly in the Attribute pane.  When inputting a value that falls outside the assigned domain, the use receives the below warning, and the attribute edit is not able to be applied to the feature until the invalid value is corrected.
