Image catalog support for ArcPad
3075
7
04-14-2010 09:43 AM
Status: Already Offered
EmilTucker
We would like to take high-resolution orthophotogaphy in the field and use it as a background layer in Arcpad, however the image size necessitates clipping it into pieces so that the handheld can manage to display it.  Using an image catalog where only the images relevant to the view extent are drawn could be a way to conserve RAM and not have to switch or resample images.
This idea, Image catalog support for ArcPad, has been logged as CQ00126072. The idea is under consideration by the ArcPad team and can be tracked through ESRI Customer Care Portal located at the following url: https://customers.esri.com/index.cfm?event=login.show.
Thank you
ArcGIS Ideas Moderation Team
7 Comments
JanLippmann
hello,
i programmed a arcpad applet which "do" that for you: load/unload automatic the correct rasterfile(s) in the current mapview (with minimum scale option), the applet needs an footprintlayer.
look at:
http://forums.esri.com/Thread.asp?c=34&f=2461&t=285809&mc=17
FlashDemo_dbgRasterkatalog_ArcPAD.zip
http://forums.esri.com/Attachments/38858.zip
greetings
jan
JanLippmann
additionally a few more screenshots...
0EM30000000CiKb
0EM30000000CiKW
0EM30000000CiKR
0EM30000000CiKM
JanLippmann
sorry there are problems with inserting images..?
link for the complete flashdemo:
jan
MatthiasAbele2
Hi Jan,
how do you get the footprint layer? Is there a way to do that automatically?
Your app is also working on Arcpad 8? Is it possible to get a copy of it?
Yours
Matthias
JanLippmann
Hi Matthias,
the footprint layer you can create by exporting a rastercataloglayer with the arcpad-datamanger extension or with
gdaltindex.exe (http://www.gdal.org/gdaltindex.html)
at this time the app is  working on Arcpad only 7.1.1.
for am demoversion, please send me an email.
Yours
Jan
JanLippmann
hello,
the applet  is working now also on Arcpad 8 with service pack 4
for a demoversion, send me an email please.
jan
dot
lippmann
at
datenbankgesellschaft
dot
de
Jan
SSWoodward
Thanks for the idea!
Customers today are regularly deploying high-resolution imagery within fieldmaps, Survey 123, and other ArcGIS mobile applications. There are two main workflows for achieving this.
1. Generating a tpkx package from pro that can be side-loaded to the device
https://support.esri.com/en/technical-article/000021232
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/data-management/create-map-tile-package.htm
2. Publish your imagery as a raster tile service that supports export and download to the device.
https://doc.arcgis.com/en/arcgis-online/manage-data/publish-tiles.htm
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/web-tile-layer.htm
