FGDC Metadata Data Quality fields should appear by default in ArcGIS-format metadata "Item Description"
1015
04-02-2012 08:51 PM
Status: Closed
ErikSandin
(submitted on behalf of the Great Barrier Reef Marine Park Authority)
The FGDC metadata fields found under the "Data Quality" element should appear in the "Item Description" display of ArcGIS metadata:
Data quality:
-Attribute Accuracy
-Logical Consistency
-Completeness
-Position Accuracy
-Lineage
--Process Step
---Process Description
Business case:
The purpose of metadata is to provide a channel for a data provider to communicate vital information about GIS data to the data consumer. FGDC metdata is an accepted standard in which data providers have made an investment and with which data consumers are familiar.
The Great Barrier Reef Marine Park Authority maintains metadata records for over 700 GIS data sets. Many of these data have important implications not only for conservation of this unique resource, but also safety of navigation and even issues of international jurisdiction. GBRMPA have invested hundreds of hours in the FGDC metadata standard specifically to make sure that users understand the appropriate use and limitations of these data.
By displaying by default such FGDC fields as those above, ESRI could both save customers hundreds of hours of rewriting metadata. Most importantly, ESRI would be cooperating with data providers and consumers to ensure against misuse of data which could be both costly and dangerous and which metadata standards are intended to combat.
3 Comments
curtvprice
I don't totally agree with this thing but the item description is a bit too sparse for my taste as well. Some of those fields should be visible by default.
AletaVienneau
The brief Item Description isn't designed to support people who must create standard-compliant metadata content. This default style of metadata includes the content that is published or shared with items to ArcGIS Online and the content that is indexed and used by ArcGIS for Desktop Search. It is designed to support people who want to use the full capabilities of ArcGIS but aren't yet committed to fully documenting their items.
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the ArcGIS Pro Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to duplicate ArcGIS Pro Idea
