Subtype/Asset group lookups using Data Loading Workspace tools
3302
12-18-2020 07:20 AM
RichMoore
We have a source feature class with multiple Subtypes that map to the Sewer Network like this:
Source feature classSubtypeDescriptionTarget feature classAsset group
NetworkStructure6GateSewerDevice27
NetworkStructure1DischargeSewerDevice22
NetworkStructure7WeirSewerDevice26
I can use a query in the DataReference.xlsx to select the Subtypes I want:
SourceDefinitionQuery
subtype in (6,1,7)
My question is ... How do I specify the correct Asset group?
Do I need a separate row for each target Asset group in the "SourceTargetMapping" sheet in DataReference.xlsx?
Or can I create an expression that maps the Source Subtype to the Target AssetGroup in the "MappingWorkbook"?
I can get the domain table lookups to work, but I haven't figured out how to do Subtype lookups.
Thanks, Rich
AllysonReynolds
Rich,
As far as I understand it, yes you will need a different row for each asset group in the DataReference workbook. I've truncated the entire path name here so it would fit in the image, but it's like this:
From that image, you can see that for each of those rows, a different MappingWorkbook also needs to exist. Though, those are generally pretty much the same, at least for me, so far.
AllysonReynolds
Not sure if this attachment might be easier to see/read.
RichMoore
Thanks Allyson.  I found an alternative method that does this similar to mapping domain tables.  The attached graphic might help to explain.
AllysonReynolds
Rich,
That seems much more efficient. Thanks so much for sharing!
-Ally
