Create Data Loading Workspace ERROR
2226
6
06-14-2023 07:51 AM
MaikHeinze
Hello everyone,
I have a problem importing my data. I'm using the tool called "Data loading tools" and I want to create a Data Loading Workspace (dlt). When I run the tool, the following error message appears.
Does anyone have experience with this and can help?
Kind regards, Maik
TedHoward2
Could you share what parameters inputs you are using?
MaikHeinze
I am using Shapefiles.
TedHoward2
Shapefiles are supported so something strange is happening. It would help to see the "Source to Target Mapping" value from the Parameters tab.
You can also put the tool into debug mode via the Python window
import dltsolutions
dltsolutions.logger.setLevel("DEBUG")
Run the tool again and you may get some more detail.
MaikHeinze
Unfortunately, that doesn't work either 😕
TedHoward2
There is a problem handling parameters when is localization installed. Should have a fix in the next day or two.
TedHoward2
This should be fixed on dltsolutions 2.9.6
