DLT - Mapping questions
1217
06-29-2023 10:01 AM
spiderman90
Hello ,
i am new with using DLT tool ,
 the output of this tool provided data reference and the mapping file .
But mapping file did not assign any domains , and also did not generate  any new  blue sheets.
This file includes only mapping sheet ,source subtypes ,source schema,target subtypes and target schema .
why did not assign any new blue sheets ?
mapping : it provide me number of asset group but values for  asset type was empty .
1.why asset type is empty although I have four asset types for this feature class ?
2.why did not assign any domain ?
i have 3 domains for specific fields but it did not assign any .so how to assign domains ?
3.why did not generate any of blue sheets ?
4. SourceDefinitionQuery ?
it was empty column at my data reference .
i am not sure ,how to use it .is it necessary to use ?
TedHoward2
I'm unsure what you mean by assign domains, but these tools do not create domains. They only help map data from a source domain to a target domain.
Blue sheets are only created if fields in your Source class/table have domains.
SourceDefinitionQuery is for applying definition queries to filter what data is loaded to target and should be written with SQL (the same as applying definition query to a layer in a map).
