Edit CrowdSource Reporter Pull Down Menu
1377
06-04-2020 01:58 PM
SteveRhyne2
I created a Geodatabase with different point layers and assigned domains to specific fields. In the domain menu I have the code and a description. As I understand it, the description is what drives the pull down menu in the form for CrowdSource Reporter. However, the pull down menu is showing the code and not the description. For example, the pull down menu displays "BikeConn" when it should read "Bike Connectivity" In the web map containing the layers, the descriptions display correctly in the table of contents, and when I add geography, the pull down menu choices are correct. This issue started after I updated my service.
Any thoughts?
Thanks in advance for your help.
Steve
SteveRhyne2
I fixed the issue. I learned that symbolizing your layers in ArcMAP prior to uploading your service can cause issues with the CrowdSource form. I changed my symbology to one simple shape for my layers and reloaded the service and that fixed the pull down menu issue. I changed my symbols in my online map and Wha La!!! All good.
