Delete facilities in the hosted feature layer then update the layer
693
04-13-2020 03:38 PM
Bogatirsky_Nathalie
New Contributor II
I'm trying to clean the facilities hosted feature layer as I  have facilities that I don't want to delete.
When I try to edit this layer into ArcMap, I got an error message letting me know that the layer is not editable (but it is when I looked into AGOL).
Any procedure that I could follow to delete all the previous facilities and append the data with new facilities?
Thanks
Nathalie
JakeSkinner
Esri Esteemed Contributor
Hi Nathalie,
I would recommend using ArcGIS Pro.  You can use the Delete Rows and then Append tools directly on the service.  Using ArcMap, you will first have to create a local copy for editing from the service, make your edits, then sync the data back to the service.
You can also try this tool, which will work in ArcGIS Pro or ArcMap.
Bogatirsky_Nathalie
New Contributor II
Thanks a lot Jake
