What is the PARAMETER["Height"] in CRS?
1365
11-17-2016 03:07 PM
LorenDawe
A client has provided a PRJ file (attached) that contains a "Height" parameter:
Well-known text PROJCS["PTL1_Buenaventura",GEOGCS["GCS_MAGNA",DATUM["D_MAGNA",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["IGAC_Plano_Cartesiano"],PARAMETER["False_Easting",100000.0],PARAMETER["False_Northing",100000.0],PARAMETER["Longitude_Of_Center",-76.85094890833329],PARAMETER["Latitude_Of_Center",3.85779813888889],PARAMETER["Height",315.0],UNIT["Meter",1.0]]
I have three questions regarding this:
1 - What does this refer to?
2 - Does this parameter affect the horizontal coordinates in a transformation/re-projection?
3 - Can this be applied using PROJ4? If so, how?
Thanks in Advance,
Loren.
MelitaKennedy
Esri Notable Contributor
It's a parameter peculiar to this map projection algorithm--IGAC_Plano_Cartesiano. It's used for large scale data, generally a city. In a sense it's a scale factor, adjusting the horizontal coordinates based on the height of the city. It reduces the overall distortion, because the projection plane is located close to the GCS/ellipsoid surface. Adding in the height above that surface moves the plane to the local average elevation, so distances, etc. are closer to true.
EPSG has the same definitions, but calls the projection "Colombia urban". Neither EPSG nor Esri have a predefined definition for Buenaventura.
Unless it was added very recently, PROJ.4 doesn't support this projection.
Melita
