Transform MANUALLY WGS84 to NAD83 CSRS
3127
5
12-22-2020 07:24 AM
akisai
I wanted to use the coordinate frame rotation method to transform MANUALLY WGS84 to NAD83 CSRS. Some of the parameters to do so are given in meter (dx, dy and dz). I tried many times to do this transformation using the formulas for this method. But no result concords with the values given by ArcGIS when I do this transformation using this software.
could you please tell me if I have to transform some parameters in other units before applying the formulas.
lat/long of my point in WGS84: LAT=47.562060394000000 LONG=-52.740740910000000
formulas:
M=(1+dS*10^-6)
XT=M*(1*Xs-Rz*Ys+Ry*Zs)+dx
YT=M*(Rz*Xs+1*Ys-Rx*Zs)+dy
ZT=M*(-Ry*Xs+Rx*Ys+1*Zs)+dz
parameters: dx=0.991000000, dy=-1.907200000, dz=-0.512900000, rx (second)=0.02578991, ry (second)=0.00965010, rz (second)=0.01165994, ds=0.000000000
Expected (ARCGIS) - From WGS84 to NAD83_CSRS:
LAT=47.562050544
LONG=-52.740746617
Thanks for your help
Pål_Herman_Sund
Hi. One thing which sometimes cause issues are the signs/orientations, i.e a positive angle can be clockwise or counterclockwise. The R's are rotation matrixes and programmatically you would convert the r's to radians prior to compute the needed cos(r) and sin(r)
BojanŠavrič
Hi @akisai,
Transformation parameters you are using match NAD_1983_CSRS_To_WGS_1984_2 (WKID::1946) transformation, but they have opposite +/- signs. From your formulas, I see your rotation matrix matches the one for Position Vector and not the Coordinate Frame method. In your case, you are trying to apply the transformation in reverse (from WGS84 to NAD83 CSRS) by using transformation parameters and rotation matrix with opposite signs as they are originally defined. I would need to verify the math first, but I suspect your approach might not match the exact reverse formulas used in ArcGIS.
Please see EPSG Guidance Note 7.2 for detailed (exact reverse) formulas and the table of Geographic Transformations in ArcGIS Pro 2.7.
I hope this helps...
AJ_devaccount
Hi @BojanŠavrič @MelitaKennedy  would it be possible to confirm if my formula is correct please? I'm trying to convert WGS UTM to NAD UTM: WGS_1984_(ITRF00)_To_NAD_1983 (Coordinate frame)
parameters: cx=0.9956, cy=-1.9013, cz=-0.5215 (documentation, pg 111)
rx (second)=0.025915, ry (second)=0.009426, rz (second)=0.011599 (I've changed to radian in formula)
ds=0.00062
Xa=608710.585168, Ya=4829046.82889
Xb=608710.880294, Yb=4829045.88214 (from Pro2.7)
Xb=608711.3096, Yb=4829044.965 (from below formula)
Also I wasn't able to access the EPSG document in your above reply, the link might be broken now?
Thanks very much!
akisai
Hi
Thanks for you answer and proposed documentation. It is very helpful
I will check from my end the signs of the parameters in relation with the method
I also noticed from some reading that this transformation has to follow the following order: Geographic to Cartesian -  Cartesian to Cartesian - Cartesian to geographic
Have a great day
Pål_Herman_Sund
Correct @akisai both methods (Coordinate Frame and Position Vector) are Cartesian (geocentric) transformations hence You have do convert the input lat/long to XYZ prior to transformation and XYZ to lat/long afterwards on the result. pH
