Raster Projecting Incorrectly
12983
14
08-17-2017 03:03 PM
GlendaWyatt
My map is in NAD1983 UTM Zone 9N.  I am importing a raster that (when opened on it's own) looks fine and is in WGS84.  When I add the raster to my map, it projects incorrectly.  Any suggestions on how to start resolving this would be greatly appreciated.  The raster was exported from Q.
DanPatterson_Retired
So to 'fix' this, you need to know the real world extent of your input file in longitude/latitude coordinates.
The coordinate definition of WGS84 is wrong since the raw row/column format has to be translated
row/col  long/lat
0,0        -180, 90
0, 192    180, 90
128, 96      0, 0    Greenwich, Equator
192, 0    -180, -90
192, 256 180, -90
so you have a cell size in the long/lat (ie X,Y) directions
I assume Q can't finish the provision of real world coordinates.
GlendaWyatt
Luckily, my input is the entire earth surface with the western edge being at Greenwich.  Do you know if there is a way to define this in ArcGIS without having to register points?
GlendaWyatt
I'm also going to try to georeference in Q and then try Arc when I am back in the office tomorrow.  Thanks again for your help.
Naby79
I have the same issue. I know the real world extent of the file, how to update it?
MelitaKennedy
Esri Notable Contributor
That was actually my comment and should have had a "not" in there: ...the raster extents are not in decimal degrees...
