Database Connections
450
11-14-2019 04:51 PM
BeverlyRichey
Upgraded ArcGIS from 10.4 to 10.7 last week. Received new data to update one of our map services. I stopped the map service in ArcCatalog and I am then suppose to delete the outdated data from our SQL database connection (sde). Before the upgrade, I was able to select the feature > right click and then delete. And yes, I have admin privileges. I thought that I might have lost admin rights when I upgraded. I reconnected to the database with as administrator again and that feature capability is still not there. Is this function not available anymore. What is the work around? I hope I do not have to downgrade back to 10.4 to have this functionality. Thank you.
B.R.
