What's the intended use case for the quote button in post replies?
The toolbar when replying to a post (has blockquote and quote buttons):
The toolbar when creating a new post (only has the blockquote button, not the quote button):
Thanks.
@Bud wrote:What's the intended use case for the quote button in post replies?
Thanks.
The quote button adds the content from the message you're replying to.
The block quote button allows you to emphasize a section of text is coming from another source
This is important!
Thanks.
This is important!
Do you find you use the quote functionality much? I wonder if the UI/tree serves the same purpose when making replies.
Not really. I find it irritating that it give you the entire body of the message. I'm usually only interested in quoting a portion of the text, which means I have to go in and remove all the extraneous stuff .
For that, I just use the block quotes...
Personally, it doesn't bother me that much, because I often have to expand the toolbar anyway to get to the code button...
