Redirect errors in Edge and Firefox
2733
11
02-28-2023 05:54 AM
KenBuja
MVP Esteemed Contributor
I cannot log on to the Community in Firefox or Edge. I am getting redirect errors, even after clearing out all the cookies. I can only log in using Chrome.
Firefox:
Edge:
MobiusSnake
MVP Regular Contributor
I'm seeing this issue too, also happening to me in Brave.
DanPatterson
It happened to me yesterday too using Edge. clearing cookies eventually worked, but I eventually got a "accept cookies" dialog pop up.  I suspect it had something to do with something on the site changing recently with the cookie policy where you can specify the type you want to allow
... sort of retired...
JesseCloutier
Esri Community Manager
Thanks for providing these details, @KenBuja, @MobiusSnake, and @DanPatterson. @SimiBasu, tagging you for visibility and follow-up.
Jesse Cloutier
Community Manager, Engagement & Content
SimiBasu
@KenBuja @DanPatterson @MobiusSnake could you please try logging out and logging back in and see if you still have this issue. We moved to a new release yesterday night/early morning and I want to be sure if you are still seeing this issue before we investigate this further. Thanks.
DanPatterson
I have been good for 2 days
KenBuja
I'm still getting the redirect errors. In Firefox, I went into setting and blocked the cookies for the site. Now when I log in, I get a blank page with this URL: https://community.esri.com/ccqpr47374/plugins/custom/esri/esri/custom.oauthsso-redirect?state=https:...
I then open the Community URL again and when I attempt to log in, I get redirected to the account page saying there's a technical problem.
Here's a video of what happens
(view in My Videos)
KenBuja
An update.
I removed the cookie exception in Firefox and restarted it. Now I am able to log in once again. However, I'm still getting the same error in Edge.
SimiBasu
Thank you @KenBuja  I am checking on the Edge issue.
philnagel
I was able to get it to work in Firefox by manually deleting cookies & site data for the domain esri.com. Go to Settings, Privacy & Security, Manage Data and search for esri.com, then select Remove All Shown & Save Changes.
Then I had to log in again and have not had the issue since. The same may help in Edge, though the specific procedure to delete specific site cookies is probably a little different.
