Hyperlink in a quote — Ending the quote removes spaces around hyperlink
1893
01-14-2024 03:18 AM
Bud
Legendary Contributor
Regarding Esri Community posts (questions and ideas):
There is an issue with hyperlinks in quotes.
Example:
I've pasted some text that contains a hyperlink into a quote. I hit enter, then hit the quote button to end the quote. The act of ending the quote has removed the spaces around the hyperlink.
I think that happens sometimes with bolded text too.
Could that issue be fixed? I don't want spaces to be removed around hyperlinks. Thanks.
Video:
(view in My Videos)
Environment:
Windows 10; Google Chrome 120.0.6099.217 (Official Build) (64-bit)
JesseCloutier
Esri Community Manager
Hi @Bud, I've just done a bunch of testing to try and replicate this—both by responding to ideas and questions comments—but was unable to reproduce what you captured in your video. In all cases, spaces remained around the hyperlinked text and bold text when toggling the quote feature on and off. Are you still experiencing this?
Jesse Cloutier
Community Manager, Engagement & Content
Bud
Hi@Bud, I've
Hi@Bud, I've
Hi@Bud, I've
@JesseCloutier Yes, I still see the issue.
Video:
(view in My Videos)
Thanks.
JesseCloutier
Ah, there we go. I see what the difference was. When copying and pasting text with a link that comes from within Esri Community (while keeping the formatting) I was able to replicate your experience. There doesn't seem to be an issue when copying text with a link from another source like Word or from Notepad and then adding the hyperlink. If you instead copy and paste from another source, or clean up the formatting by dropping it into Notepad, or past as Plain Text and then hyperlink, does that work? @SimiBasu, tagging you for visibility.
Jesse Cloutier
SimiBasu
Hi @Bud  after analyzing this issue, we found out that this is a bug in the current platform that creates a  "&nbsp" (That is a space creating before and after the hyperlinks when the space bar is pressed). I am working with the vendor to see if this Bug can be fixed. But, as mentioned above the workaround for now is not to copy paste to avoid this issue as that creates a default &nbsp
@JesseCloutier FYI
