How do I get to 'My Content'? I have started draft blogs/posts - but there is no 'my stuff' location...?
3733
6
03-16-2021 08:36 AM
BrianBaldwin
I might be losing my mind, but I can't find anyway to get to draft content.
If I start a blog and save it as a draft... where is it? How do I get access to it?
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
by Anonymous User
Not applicable
Hi Brian, Go to the place's blog board where you created the blog, and you will see a Blog Dashboard in the bottom right column where drafts are saved.
You will see a (1) in the parenthesis for View All Drafts in the place you saved your blog.
by Anonymous User
Not applicable
LauraBowden
Esri Alum
Hi @Anonymous User , it would be great if this information were added to your Help blog post about how to write a blog. Unless a blog is pretty short, I think most people would save a draft before publishing.
Laura Bowden
by Anonymous User
Not applicable
Hi Laura, The doc is now updated. Thanks!
JosephKerski
Esri Alum
Thanks!  This often happens to me as well... "where are my drafts"???  Joseph Kerski
BrianBaldwin
Awesome! So, I'm not losing my mind - thanks @Anonymous User. While I am glad it exists, I think it would be great to have any blogs/drafts/etc. roll up to a central place where users could locate them more easily.
khawarsohail
Greetings, Brian. If you go to the blog board where you created the blog,you will see a Blog Dashboard in the bottom right column where you can save drafts. Check your Google Search Console.
