Hello!
I would like to add a crowdsource feature layer in ArcMap, but there is an error.
It isn't possible too, to open such a layer (e.g. NPSMemories of ESRI Crowdource storymap) in ArcGIS.com Map
Have some of you these problems too?
Thank you!
DORIS,
I believe this is due to a bug we are aware of that is present in the current beta version of Crowdsource. The bug is related to how the feature service is created.
We are looking into this and should have a fix for it in the next release in September.
Owen
Hey Doris,
you can go to the webmap that is used in your story map. Click on "Show Item Details" ( see screenshot).
Then under Layers click on "Export to" and choose which format you would like to have the data.
Hope this helps!
TIm
Thank you TIm for your Idea, but I don't want to export the data of this layer I would like to use it as a featureService (live-link) in ArcMap; therefore the actuality should be ensured , if someone upload new photos in the storymap.
DORIS,
Owen
Ok, thank you Owen!
That calms me - September is coming soon ;-). Is there a specific date for the next release?
It will be in mid-Sept.
